Page 59 of 75
FirstFirst ... 9 49 57 58 59 60 61 69 ... LastLast
Results 1,741 to 1,770 of 2222
  1. Originally Posted by Marchand View Post
    x265 Builds for Windows Cross Compiled with MinGW by snowfag
    FYI those builds don't work on Windows XP: "Not a valid Win32 application".
    Aug 2013
    Central Germany
    Not everyone here still cares about obsolete operating systems... I only do because it was just a simple flag for the build script.
  3. DECEASED
    Jun 2009
    Heaven
    Marchand has become a "post whøre". Quite unfortunate indeed.
    Last edited by El Heggunte; 13th Dec 2014 at 16:07. Reason: Google is pure evil >_<
    Jan 2014
    Kazakhstan
    Who has the desire make rip out this sample > Park Joy (mega.co.nz).
    Preferably bitrate 6800-7000kb/s, and your recipe for maximum quality.
  5. Sounds like a waste of time:
    a. presets&co are still changing every few weeks (in example aq-mode 1 is now the default)
    -> so suggesting any base line settings will be troublesome
    b. optimizing settings for a single source and bit rate combination seems like a waste of time
    better try to figure out which psy-rd settings make sense for what bit rate, since:
    The lower the bitrate, the lower the optimal psycho-visual settings. If the bitrate is too low for the psycho-visual settings, you will begin to see temporal artifacts (motion judder). This is caused when the encoder is forced to code skip blocks (no residual) in areas of difficult motion because it is the best option psycho-visually (they have great amounts of energy and no residual cost). One can lower psy-rd settings when judder is happening, and allow the encoder to use some blur in these areas of high motion.
    source: https://bitbucket.org/multicoreware/x265/commits/9c3b478a60b27aa118b0eb71e8d495016a028...c/reST/cli.rst
    doesn't really help without some general hints how to decide what psy-rd settings are too low what bit rate on what content.
    Cu Selur
    Jan 2014
    Kazakhstan
    Very convenient to pick up the settings on the passive stage, but that's very sad when'll see what happens when applied to complex scenes (garbage).
  7. Originally Posted by Gravitator View Post
    6500kbps, Placebo, and some tweaked settings
    Aug 2013
    Central Germany
    I will call everyone recommending preset placebo a troll. As well as everyone asking for maximum quality at limited size.
    That said ... another weekly: x265 1.4+209-6ba7be7b1697
    Jan 2014
    Kazakhstan
    Please adhere to the bitrate 6800-7000kb/s (abr/2-pass).
    I can not start this file in MPC player (requires codecs) Looked through the converter Hybrid
    - In general, you have a good work out
  10. "requires codecs" HEVC shouldn't require any codecs with MPC-HC, assuming one isn't using an old version
    Aug 2013
    Central Germany
    MPC-HC (v1.7.7, Dec 2014) is not the same as MPC (v6.4.9.1, Feb. 2010); more than 4 years ago, HEVC was not even published as draft standard yet (that happened 2 years later).
  12. DECEASED
    Jun 2009
    Heaven
    There's something odd with the file "park_joy - test (p).encode.mkv",
    LAV Splitter 0.63.0 refuses to connect to the File Source filter
    The thing plays fine with MPlayer and ffplay though
    EDIT: apparently it's something to do with this
    EDIT 2: just confirming, the upgrade to the latest revision (57ca857ffbb5) fixed the problem.
    Jan 2014
    Kazakhstan
    Sorry It was a MPC-HC 1.7.7 through LAV v0.6.3
    Thanks for the news
  14. DECEASED
    Jun 2009
    Heaven
    build 1.4+217-78ae7996a1ce
    (compiled with GCC 4.9.2, finally \o/ )
    Changes since commit 775ebb4
    chenm003      295d033   fix: output wrong WppEntryOffset when emulating start code at end of WPP row
    Steve Borho   42fb030   doc: improve documentation for --stats and multi-pass in general
    Steve Borho   3315d6c   ppa: minimize code foot-print of profiling events
    Steve Borho   952a2a3   ppa: simplify interfaces, enforce coding style
    Steve Borho   6cbd7d2   ppa: refine event names
    Steve Borho   78ae799   ppa: emit one event per CTU for more clarity,
                                 disable frame threads events
  15. DECEASED
    Jun 2009
    Heaven
    build 1.4+219-8d2f418829c8
    Changes since commit 78ae799:
    David T Yuen     7b816fd     asm: idct[8x8] sse2 12232 -> 3500 over c code,
                                 3550 -> 3500 over intrinsic
    ????????????     8d2f418     fix 4:4:4 rd<=1
    Aug 2013
    Central Germany
    Belated Merry Christmas: x265 1.4+223-1bf769c6953d
  17. DECEASED
    Jun 2009
    Heaven
    build 1.4+236-8379ff016b56
  18. Member
    Aug 2013
    Central Germany
    Looks like some "Evangelion"?
  19. DECEASED
    Jun 2009
    Heaven
    ¿Anta baka? EVAngelion happens in 2015!!
    Aug 2013
    Central Germany
    Ah, didn't know. Just like "Back to the Future" went to 2014, and we invented Hoverboards?
    Well: Happy and healthy 2015!
    Jan 2014
    Kazakhstan
    Ask to evaluate my > ideas
    My goal is to give the opportunity to earn money rights holders and various developers (interest).
    Happy New Year!!!
  22. Member
    Jan 2014
    Kazakhstan
    Boring to watch a lack of competitors x265
  23. Member
    Aug 2013
    Central Germany
    Happy New Year: x265 1.4_244-f255e8d06423
  24. Originally Posted by LigH.de View Post
    Thanks!
    Frohes neues Jahr - Happy New Year to you too
  25. DECEASED
    Jun 2009
    Heaven
    @all: Obey her, or suffer the consequences
  26. DECEASED
    Jun 2009
    Heaven
    build 1.4+251-feebd0ecda69
    Changes since commit f255e8d:
    Divya Manivannan   79b9453   asm: psyCost_pp_32x32 in sse4: improve 110849c->13373c
    Divya Manivannan   b117e00   asm: psyCost_pp_64x64 in sse4: improve 417824c->56347c
    chenm003           935eb35   testbench: fix bug in generate weight input data
    Gopu G             e3039bc   encoder: initialize analysis data to null
    Praveen Tiwari     a70b516   saoCuOrgB0: asm code
    Praveen Tiwari     0b6c83d   sao.cpp: fixed compiler warnings
    Praveen Tiwari     feebd0e   sao.cpp: fixed shadow warnings
  27. Member
    Aug 2013
    Central Germany
    x265 1.4+304-50a2071500dc
    CBR is no "tuning" anymore, but a stricter ABR rate control mode. Can be enforced now with separate option "--[no-]strict-cbr". Previously published option "--ratetol" is gone again.
  28. DECEASED
    Jun 2009
    Heaven
    build 1.4+374-8c66a97cd442
    Changes since commit 50a2071: too many to count 0_o
    {{ https://bitbucket.org/multicoreware/x265/commits/all }}
  29. does any one have experience with the '--cbqpoffs X' and the '--crqpoffs X' setting? (seems to be the same as qp step in x264)
  30. Member
    Aug 2013
    Central Germany
    And a few more, also fixing a Win32 compiler warning...
    x265 1.4+380-9d26082ca7b3
